Hello Terry,
To uninstall AVG Web TuneUp you can use AVG remover tool to get it completely removed from your pc.
To run AVG remover tool follow the below steps :
Please click on the below link to download remover tool
Accept the license agreement and then choose AVG Web TuneUp and remove it.
Hello Terry,
I'm not even sure which "category" to choose here! All I know is this: I have removed the AVG extension in Chrome, do not have the ASK search bar that I can find, and all other pieces of the AVG package are gone … as far as I can tell. But when I try to uninstall the AVG Web Tuneup …it will NOT uninstall. It says it is, but it stays there … over and over and over again! WHY???
