Hi Kishore and Alan ~ thank you for taking time but unfortunately although the time issue has gone away Yahoo is still telling me that I have a privacy error and will not allow me to access my sky email account. The AVG update pop-up box tells me that I have successfully updated but the main AVG control panel now says an update is required for the computor - as the computor is fairly old (so am I ) and I'm still using windows 7 I don't suppose there's much anyone can do but thanks anyway.
Max
Hello Max. Please follow the instructions mentioned in this link: http://avgread.me/1cOKH7I and then try updating AVG program. Please feel free to contact us again should you need any further assistance.
My computor says it needs an AVG update. When I try to update either by 'update now' or 'fix now' I get 2 messages. The first is a full-width screen mesage " Your computor systrm time seems to be inaccurate. This may lead to false data base up-to-dateness reporting. Please correct your system time if possible. This is immediately followed by a pop up box which says 'update completed successfully'
But the update doesn't work or doesn't register and the whole sequence begins again if I try to update again. I have check the time and time settings on the computor which are as they should be.
The outcome of all this is that I cannot log into my sky email - message reads " Your connection is not private - attackers might be trying to steal your information from uk-mg 42 yahoo.com"
and further states 'when trying to connect the website sends back unusual or inaccurate credentials. Either an attacker is trying to pretend to be UK-mg42 or a Wifi sign in scren has interupted the the connection'
The page says to try leaving it for a while - as attackers are not 'full time' but the situation remains this morning and the response from AVG is unchanged - can any one offer any assistance.
Many thanks Max
Hello Max. Sorry to know that you are facing update issues. I request you to follow the steps below to fix the update issue that you face.
Go to www.avg.com/update.
Select the update files you need (typically Virus definitions and All necessary modules for your operating system) and download them to a portable media, e.g. a USB flashdisk.
Open your AVG program.
In the menu Options, click Update from directory.
Navigate to the folder where you stored the update files, and click OK.
Please feel free to reach us back for any further queries. Thank you. Kishore, AVG Customer Care.
Max
