I thought I downloaded just AVG free but apparently I downloaded AVG Zen… I did this the other day, so I went to uninstall it, and it said I CANT. It said I have to uninstall the AVG protection first. I have no AVG Protection at all on my computer. Never have. So I need help to remove the AVG Zen. Its a glitch on the part of AVG because the AVG protection was never put on my computer, its a new computer and I've never used AVG protection on it.
SL,
We would request you to run AVG remover tool to completely remove AVG and then re install it.
Please click this link http://download.avg.com/filedir/util/AVG_Remover.exe to download and "Run" the AVG Remover tool.
To reinstall AVG Antivirus free without AVG Zen please click on the link http://www.avg.com/us-en/download.prd-afh-free and download the installation file.
Hello S L,
We certainly understand your concern.
We like to inform you that AVG Zen is just user interface for AVG Antivirus free. It will get installed along with AVG Antivirus free.
AVG Zen is an app that lets you remotely monitor the status of other AVG apps across all your—or your family’s—Android™ devices and Windows PCs. With AVG Zen, you can create a free Zen Network that allows you to remotely view the status of AVG apps installed on any of your connected computers and Android™ phones and tablets. You can also add more devices to your Zen Network, install AVG apps on your other computers, phones and tablets, and even invite your family members to join your network.
AVG Antivirus free along with AVG Zen is called as AVG Protection free program.
Do you wish to install AVG Antivirus free without AVG Zen interface?
Hello S L,
Yes. please… I tried to unistal and it said I cant. So I'm not sure what to do about it. I installed it on my PC, not on anything else. Thanks ahead of time for your help.
