Avgrsa.exe/avgidsagents.exe problem!
Hi Bobby, please read here (AVG Support Community | User Forum for All AVG products) avgrsa.exe is the resident shield component.
If this will not help, try to reinstall AVG (http://kb.avg.com/articles/it/How_to/How-to-reinstall-AVG?l=it)
I agree with Booby Ng.  I've noticed the constant high HDD reads since 2-3 months ago, I believe since build 4569.  However, I only notice the high HDD reads about 2 times per week - for example, everything will work fine for about 3-4 days, then suddenly I notice the HDD grinds - Resource Monitor points to avgrsa.exe as being the culprit.  Its almost as if avgrsa is running a scheduled scan, where its scanning system files and also static apps that are not running (with no background processes). This lasts for about 6-8 hours and then eventually goes back to normal, until it re-appears again in 3-4 days time.
My settings:
- AVG "Scan files on close" is NOT chosen.
- Expert Settings - Scan only infectible files (Always scan files without extensions is also checked).
- Cache Server is also enabled
- Also, I do not run scheduled scans (I prefer to run manual scans about once per week).
These intermittent high HDD reads has become a nuisance and it affects your productivity.  Its almost as if avgrsa is on steriods and you need to wait a few hours before it wears off.  I often need to wait hours until I can start to use any apps which are resource intensive (such as video editing).
I'm guessing the developers had re-developed the cache server.  I hope it doesn't take months for this to get resolved.  Its enough to drive your customers away fairly quickly (Note: I am a paying customer).
My settings:
As Nicholas stated the same problem, hope AVG will improve/fix this ASAP.
FYI I'm also a paid user.
Just a moment ago, I found out that my pc getting slow/lagging and I checked Resource Monitor and found out that Avgrsa.exe is the main problem! As the screenshot below…
This image is not available because: You don’t have the privileges to see it, or it has been removed from the system
Another problem is about the avgidsagent.exe, recently I reinstalled my windows and installed AVG Internet Security 2014 and this avgidsagent.exe hog up my CPU randomly! I used AVG since 2008 and I was VERY disappointed on AVG 2014 which give me so much problems.
Hi Bobby, please read here (AVG Community) avgrsa.exe is the resident shield component.
Hi all,
In order to analyze it please send us with diagnostic output (http://www.avg.com/filedir/util/AVG_SysInfo.exe) using this tool and please add detailed description of issue.
