Hi Peter,
As we're uncertain about the exact message & the process about which you're concerned, please share us the screenshots of the message & taskmanager showing the process.
Thank you for sharing us the screenshot, Peter.
Upon checking, it seems that few traces of older version is available on your computer, which is providing this pop up at startup.
Please follow the below steps to remove those traces completely & let us know if it helps :
- Download and run AVG Remover tool (https://tinyurl.com/ycrm6hz3)
- Open AVG_Remover.exe.
- Click Yes in the User Account control dialog.
- Click CONTINUE to agree with AVG’s license agreement and privacy policy.
- Select the installed version of AVG. If nothing found, click on Run Anyway.
- Click Remove, then click Restart to restart your PC.
- After restart click Run in the Open file – Security Warning dialog and allow AVG Remover to remove any residual files.
- Restart your PC again.
Hello,
Every time that i start mij computer. I get een error about AVG Diagnosticsfollowing avg proces failed and than they show AVGuiexe problem. Maybe it is known by you i think so. I am not the only one i know. I think my pc is more slow because i can see it in my cpu that it uses. Can you help me to issue the problem.
Best regards,
Peter de Haas
Hi Peter,
