Hi Benjamin,
We apologize for the inconvenience caused due to the System error. We request you to use our removal tools AVG Clear and AVG Remover:
1. Download and run the AVG Clear tool : https://share.avg.com/steam/PSP/AVG2017/AVG_Clear.exe. This tool helps remove AVG 2017 and its residual files.
2. Open the AVG Clear tool.
3. Click Yes in the User Account control dialog.
4. Click No in the Windows safe mode dialog.
5. Select the installed version of AVG.
6. Click Uninstall, then click Restart computer.
7. After restart, download and run AVG Remover http://download.avg.com/filedir/util/AVG_Remover.exe to remove all AVG products.
8. Open AVG_Remover.exe.
9. Click Yes in the User Account control dialog.
Dear AVG community,
since yesterday I have the following problem when starting my laptop (Windows Vista): The warning "avguix.exe - system error - unknown hard error" comes.
Through this problem I can absolutely nothing more download, no AVG removal tool nor a registry cleaner. You can not open or edit files in MS Word. My PC is lame - except for Internet use.
I need help urgently, because I need the PC and the data professionally.
My E-Mail: [Email Address]
Best regards
Hi Benjamin,
