Avgwdsvca.exe using too much CPU
Hello Donna,
We regret to hear about the inconvenience caused. avgwdsvca.exe is a legitimate AVG service and the name of the service is AVG Watchdog service. This process is essential for AVG to work fine. In general, the performance depends on many factors (OS type and version, HW configuration, other running applications, virus scan in progress etc.), however, the fact that there are more background process does not necessarily mean the overall performance will be lower.
Please try to run repair installation of your AVG once as described below:
Go to Start -> Control Panel.
Select AVG Protection in the list of programs.
Select Repair.
Restart your computer.
Please, feel free to let us know if you require any further assistance.
My PC has recently slowed down and avgwdsvca.exe is using up to 50%of the CPU.  What is this file and could it be piggy backed with Malware?  Please help.  Thanks.
Hello Donna,
Select Repair.
