Base filtering engine is not running
Hi Jacob,
Download BFE fix tool using this http://download.avg.com/filedir/util/AVG_BFEfix.exe link.
Run the file and follow the onscreen instruction.
Once it is done, restart the PC and check if you are able to install AVG.
Let us know the situation.
Hello,
I have tried to reinstall AVG internet security. The issue began after installing AVG tuneup. The AVG internet security was disabled and so i tried reinstallation and the error message is :
The Base Flitering Engine Service is not running!
Please help.
Jacob
Hi Jacob,
