AVG Cleaner notification reads " battery monitoring is running". I wish to stop this activity. Android phone with Ultimate AVG product. Excellent tools. - 2 weeks ago phone charge trouble… new to smartphones Sept/23. Solution found by replacing charger cord, but had started "monitoring tool".
Now cannot find "off" setting. May be a simple solution. I am still learning the operating system (OS). Best regards to all here. Thank you for any ideas, Bill
Hello William,
Thank you for reaching AVG support channel. We are sorry for the inconvenience caused.
We understand that you want to stop the battery monitoring on your AVG Cleaner for Android subscription and I'll be happy to help you out on this matter.
In this case, the "Battery Saver" setting on the device is turned off and remains off so that AVG Cleaner will automatically clean your device through its scheduled cleaning functionality.
On many devices, Battery Saver can be turned off by following the steps below:
- On Android, open Settings > Battery > Battery Saver
- Turn the "Battery saver" switch to the left to the "Off" position
This may vary from device to device but should be similar on newer devices.
However, if this doesn't work, or if you need anything else, please let me know; I'll be glad to help.
Hello William,
