How do I turn off battery monitoring? Not "battery saver" which AVG keep telling me.
Hello Chris,
You've reached the AVG community support forum.
We are sorry for the inconvenience caused. We understand that you want to stop the battery monitoring on your AVG Cleaner for Android subscription and I'll be happy to help you out on this matter.
In this case, the "Battery Saver" setting on the device is turned off and remains off so that AVG Cleaner will automatically clean your device through its scheduled cleaning functionality.
On many devices, Battery Saver can be turned off by following the steps below:
- On Android, open Settings > Battery > Battery Saver
- Turn the "Battery saver" switch to the left to the "Off" position
This may vary from device to device but should be similar on newer devices.
However, if this doesn't work, or if you need anything else, please let me know; I'll be glad to help.
Hello Chris,
