Bitdefender and Citrixworkspace problem
Hello Antonio.
Thank you for contacting AVG Support Community.
We regret the inconvenience this may have caused.
We will certainly check and help you.
Please confirm whether you are referring to AVG Firewall or Bitdefender firewall.
Also, confirm the operating system which you are using on your PC and provide us the screenshot of the firewall permission notification, we will check and help you further.
Please refer to the below article to create a screenshot.
http://https://support.avg.com/SupportArticleView?l=en&urlname=Create-screenshot
I have a serious problem: I have installed Bitdefender and I can't use my pc because every second a notification from the firewall appears to allow access to the portsca_helper.exe program. This program in the firewall has been enabled on all inbound and outbound ports, but it does not change. Same problem I have with citrixworkspace don't understand that I consent all for this program!!!
Thank you for sharing the requested information, Antonio.
We have sent you an email asking you to connect with our AVG free remote technician and please reply to that email for further assistance.
Pc is Windows 10 Pro 21H2 64bit  Experience Pack 120.2212.4170.0 the problem is AVG Firewall
Hello Antonio.
