Blacklist problems
Hello Alper,
Thank you for the screenshots.
Refer this article (https://support.avg.com/SupportArticleView?urlname=Update-AVG-Antivirus) and check if the Virus Definition is up to date updated in your device.
If yes, please submit the URL to our developers for analysis.
Click this link (https://www.avg.com/en-ww/false-positive-file-form) to submit the form.
Our developers will check and get back to you as soon as possible.
Until then you can add this website to the Exceptions.
AVG >> Menu >> Settings >> General >> Exceptions
Hi Alper,
We're glad to help you with the info.
Before proceeding with that, please clarify whether you receive any threat notification from AVG stating that the specific site is blocked.
If so, please click on 'See details' in it & then share us the screenshot for better clarity.
Meanwhile, you can submit a false positive request by visiting this link. Once you submit a request, a group of analyst will review the site & whitelist it, if it is found to be safe or goes through the clean notes of AVG.
who can answer me to remove  "TRDizin – TRDizin; from the blacklist?
this site is a governmental site and needs to do work here but avg stops. I either delete avg or move this address to the safe list.
Best,
Alper
Hi Dinesh,
Here is the threat notification track number 422d767b0d42/211222.1943+0300
ad screenshot is attached
Best
Alper
AVG Blocking trdizin.gov.tr address
Hi Alper,
