Bluetooth doesn't work after running AVG Driver Updater
Hi Hagar,
I apologize for the inconvenience caused.
Let's restore the specific driver on your PC and check if you are able to connect. Please follow the below steps.
To restore it, click the Restore tab. To restore drivers that were saved in the default system location, tick the box next to a device and click Restore. If you saved your backup in a different location, click Restore from… and locate your backup.
Yesterday I installed and ran the AVG Driver Updater on my PC (windows 7)
The updated went successfullly, but since then I can't connect bluetooth devices - my JBL charge and headphones. I tried removing and adding them again but now it won't even detect them. I checked the prefernces and everything seem to be fine. I also tried downlading the manufacturer's driver again but it said that I have the most recent version.
How do I solve this?
Hi Hagar,
