Botnet problems
Hello Roland,
We apologize for the inconvenience. We'll look into this and help you.
Please disable your AVG Internet Security temporarily and check if the issue persists.
Refer to this article to disable your AVG Internet Security.
Keep us updated.
Hi, just updated my avg antivirus yesterday and it now includes botnet support.
however my komodo coin wallet wont connect.
wont connect to any peers anymore.
Anyone able to suggest and help?
Many thanks
Roland, this doesn't seem to be an issue due to AVG.
However, we request you to completely uninstall AVG Internet Security and check the status.
For uninstallation, refer this article.
Disabled both avg and windows defender but still not able to connect to peers even though my pc can see them but just will not connect to them anymore?
they are available to connect to but will not connect.
any ideas?
