Hello Eric,
Let's have a look into this together.
Could you share the screenshot of the error message that you receive?
You can post the screenshot here in your topic. Click on "Answer" & then click on the "Image" [mountain symbol] & follow the instructions.
Thanks, but the issue was caused by AVG. I had problems accessing my Homepage, too. I then disintalled AVG Anti-Track and restarted. I now have acces to my Homepage and Wikipedia. I had both these sites on my whitelist to allow access, but it obviousl did not work. I hate to give up access to Anti-Track, but if it does not allow me to access what I need, then it is no good for me.
I have been trying to connect to Wikipedia (US or Germany) and keep getting this message: "English: Wikipedia is making the site more secure. You are using an old web browser that will not be able to connect to Wikipedia in the future. Please update your device or contact your IT administrator." I have used Chrome and Opera (both the newest versions). I suspect this could have something to do with AVG Software. I also get something similar when I try to use the "Pay Now" button on Ebay. Can anyone help with this matter? Thanks!
Hello Eric,
This isn't the experience we want you to have, Eric.
If you re-consider troubleshooting this issue further, please follow the steps mentioned in this article & let us know if it helps.
Thank you for the screenshot, Eric.
Probably, the issue is not caused by AVG and ths is related to your operating system.
We request you to reach Microsost support as they will be in the best position to help you with this.
