Hello James,
We understand your printer is not working after installed AVG subscription.
We apologies for the inconvenience caused. We'll certainly check and help you out.
As it is recommended to set the private connections as trusted in the Firewall, please change the AVG Secure VPN & other trusted networks as "I trust this network" in the Firewall settings.
1. Open AVG Internet Security and go to Protection ▸ Firewall.
2. Select the Networks tab.
3. Click Show settings next to the relevant network, then choose one of the following options:
• I trust this network: The recommended option for a private network. When you select this option, the network is marked as a Trusted network.
• I don't trust this network: The recommended option for a public network. When you select this option, the network is marked as an Untrusted network.
Each time you connect to this network, Firewall applies the appropriate settings according to your preferences.
Also, please ensure the below option on AVG Secure VPN is enabled.
1) Open the AVG Secure VPN.
2) Ensure VPN mode and Manual VPN mode are selected.
3) Turn on the "Enable local device access when using VPN".
AVG AntiVirus monitors all network traffic between your PC and the outside world to protect you from unauthorized communication and intrusions. Enhanced Firewall feature is designed to require minimal input from you. To ensure you are protected, all you need to do is keep Enhanced Firewall enabled with setting up the trusted connections.
If you run into any trouble, or have any questions, feel free to message me. We’d be happy to help.
This software was purchased for a fire department. I am unable to print to any network printers unless AVG is uninstalled. No matter what, it changes all networks to PUBLIC and blocks activity, even if I enable it. I'm about to cancel this subscription.
Hello James,
