Cannot reinstall after attempting to fix "UI won't load" problem
Hi Brixton.
We're here to help.
Please run AVG Clear tool to remove traces from the previous installation and reinstall AVG AntiVirus free.
Click this link to download and run AVG Clear tool.
We appreciate your effort in this.
AVG Secure Browser will not deny you from reinstalling.
Do you have any security application(s) installed in your PC other than AVG?
This is could be a possible reason for the unsuccessful installation.
If yes, kindly uninstall those and use the clear tool again.
Restart the PC and try to install AVG Free again.
Keep us posted.
I recently updated AVG, and wanted to scam my PC. AVG brought up something along the lines of "This is embarrassing, the UI won't load," so I looked it up and followed the steps provided. Uninstalled AVG, restarted PC a few times. I reinstalled the AVG setup and tried to reinstall the free version of AVG. It started the download, and the download progress bar filled up, but nothing happened. AVG anti virus is not on my computer, but the AVG browser is? Any suggestions/fixes?
Hi Brixton.
We're here to help.
Do you mean to say that AVG is not allowing TellTheBell Portal to load?
We appreciate your efforts, Brixton.
Glad to hear that AVG is installed and activated successfully.
Hello Avinash, I downloaded and used the AVG Clear tool, and attempted to redownload AVG again. The same result happened. I'm starting to think it's because AVG Secure Browser never was removed. Thank you for helping me through this, and I hope we can get this solved!
Are you unable to access  the TellBell application after the installation of AVG?
Please elaborate the issue in detail.
I uninstalled McAfee since it came pre-installed on my computer and my free trial expired. AVG is back on my computer! Thank you both for helping me out!
