Cant uninstall AVG web tuneup (I've tried using the removal too, no success)
Tyler,
Could you share a screenshot of the page (from where you want to uninstall it) to proceed further.
You can post the screenshot here on your topic. Click on 'Answer' & then click on the 'Image' [mountain symbol] & follow the instructions.
Regards,
Hello Tyler,
We are here to help. May I know if you're trying to uninstall AVG Web TuneUp from control panel > program and features? What exactly happened when you try to uninstall it? Is there any error message? If yes, then please share a screenshot of the error message to proceed further.
Regards,
Okay, Tyler.
Please reboot your device in safe mode:  http://support.avg.com/SupportArticleView?urlname=How-to-reboot-your-computer-into-Safe-Mode and then proceed with remover tool http://support.avg.com/SupportArticleView?urlname=How-to-uninstall-AVG .
Can I get some support from AVG on un-installing the web tuneup tool
I went into settings>apps>avg web tuneup>uninstall and nothing happened. A different thread on here has a removal tool link in the comments for the same problem, I used that but it didnt work.
I am happy to hear that your issue is resolved.
I appreciate your time and co-operation.
Clearing out everything manually in safemode did the trick, thanks!
Hello Tyler,
Regards,
There's no error to show you or anything like that, im guessing you know what the uninstall page looks like in settings on windows 10?
a screenshot seems unneccesary for my situation
