Connection problem on chrome
Hello Muhammet,
Let's have a look at it together. We need to check with the settings. Open AVG Internet Security -> Menu at the top right -> Settings -> Components -> Enhanced Firewall -> Customize -> System Rules -> make sure all the task has been enabled.
Again, Firewall -> Customize -> Network Profiles -> change all the profiles from public to Private and then check with the status. If the issue persists, share the screenshot http://support.avg.com/SupportArticleView?urlname=How-to-create-a-screenshot of the error you received.
Muhammet, If applicable… For your info, just in case that you are unaware, you can post the screenshot here in your topic. Click on 'Answer' & then click on the 'Image' [mountain symbol] & follow the instructions.
hello all.I have a problem.I can't connect internet pages.But when I stop web protection I can connect everything.When I start it can't.On opera and firefox no problem.What can I do ?
Hello Muhammet,
