Hi Mehmet,
Please let us know the operating system of the device in which you're experiencing the issue & what happens exactly while accessing it.
The image that you've attempted to upload in your post, isn't visible.
Would you be so kind to reupload it?
I keep getting errors when I try to use the program. I have repeatedly tried deleting the program and reinstalling it. But I could not reach any solution. I still keep having the same issue.
My OS is windows 10 Pro 20H2 Version 19042.804. When connecting with AVG Secure VPN, it warns that you are offline please connect to the internet to use vpn. I tried several methods, including uninstalling and reinstalling flsuhdns commands, but couldn't find a solution.
https://i.imgyukle.com/2021/03/10/NHKlQH.jpg
Turkey's government has imposed restrictions on access to all commonly used VPN service networks, including AVG, Mehmet.
