Hello Kris,
We are really sorry for the inconvenience caused. We can really understand your frustration. We will check and help you to resolve it. Please provide the following information to help you better :
1. Have you tried to repair or reinstall AVG Internet Security?
2. Confirm the version of operating system installed in your device?
3. Kindly share us the screenshot of the pop-up which you keep getting from AVG.
You can post the screenshot here in your topic. Click on Answer & then click on the Image [mountain symbol] & follow the instructions.Thanks in advance.
I am fed up of a pop up constantly opening with different programs listed
whether to allow INCOMING/OUTGOING CONNECTIONS OR INCOMING ONLY OR HTTPS ONLY EVERY 2 MINS this is extremely annoying how do I stop this constantly asking
I'm have a similar problem - what setting is causing the error unsecure connection - didn't get a valid response from websites I have beeb using for years. I'm a a loss to determine what is causing the problems but guessing it has something to do with the VPN
Hello Robert,
To proceed further, please create a separate AVG community post by clicking the link below and post your questions in your own post, so we will check with your AVG account and help you accordingly.
Hello Kris,
