Continuing problem with popup
User-added image
As requested, here is what I get in the continuing popup every time I use chrome
Thank you very much.  I did reset the brower and it seems to have solved the problem.
Linda, we are glad to know that the issue has been resolved.
User-added image
Thank you for writing back to us in your own post, as requested, Linda.
Upon checking the provided screenshot, we see that Web Shield has blocked some java script on your Chrome browser.
Some webpages/extesnsions running in Chrome might attempt to reach a malicious source, which was blocked by AVG.
In this regard, we'd suggest you to check & remove any unwanted extensions installed on your browser. If nothing found, you can attempt to reset the browser once to check.
I have scanned my PC (and do so regularly) and no threats found but this continuing popup is a bit troublesome!  Please tell me how to get rid of it!!  Thank you
