Dashline and AVG PRO
OK - I disabled AVG as advised, everything work the way it use to be before AVG PRO. How do I resolve the problem when AVG is protecting my computer like it was prior to using AVG PRO?
Hello David,
We apologize for the inconvenience. Please disable the AVG Protection temporarily and see if you are able to login to Dashline automatically. Please click on this link for the steps to disable AVG temporarily http://avgclick.me/TempDisableAVG
I have been using AVG for a long time with no problems with DASHLINE until I downloaded AVG-PRO. Now DASHLINE will not AUTOMATICALLY log me into the accounts that I stated for it to do it.
Is there a setting within AVG-PRO that I need to setup?
Dave
Hello David,
Thank you for replying us back.  Please try to repair the AVG program and check whether it resolves the issue. Please follow the instructions on the article avgclick.me/RepairAVG to repair your AVG program.
Hello David,
