Delete SYSTEM_32 problem!
Hello Fishy,
We do understand your concern. We appreciate your time and co-operation in bring this to our concern. You can send your feedback on your AVG product from this link and it reaches the concerned team http://avgclick.me/AVGfeedback
Thank you
I love everything about the anti-Virus but my only worry is that it wont scan for a simple line of code that deletes system 32. so the anti virus protects you from extreme threats but not the most basic ones. am i wrong? do you do this already? if not that would be a good idea to add that protection issue.
because its very easy to delete it…
cd windows
del system 32/.
del system32
and your computer is now a huge brick and you have to reinstall everything
Hello Fishy,
Thank you
