So. When I tried to remove AVG (because I'm using Trial and it's ending soon), there were 3 components. ZEN, PC Tune Up and Protection. I removed PC Tune Up just fine, but Protection always stopped at 2%. So I searched the internet and tried using AVG Remover to remove. However, it only removed ZEN but not Protection, and after that it gave an error code (I cannot remember which) whenever I opened the Uninstaller. So, I decided to use Clear to remove that part. However, it stopped when it was trying to use something - relating to firewall.
The next time I opened the computer, now, almost every services is disabled. Internet, Itunes, etc… My PC is isolated. I cannot Repair AVG since the Uninstaller has disappeared in Control Panel, and i cannot install AVG again because there's no internet. A god damn limbo.
Someone please help immediately.
Hello Duc,
We truly apologize for the inconvenience caused. We request you to remove the AVG traces by running the AVG Clear tool and the remover tool. Here are the links:
AVG remover tool: http://download.avg.com/filedir/util/AVG_Remover.exe
AVG Clear tool: https://share.avg.com/steam/PSP/AVG2017/AVG_Clear.exe (NOTE: Click NO when the tool prompt for a restart in Safe mode).
Once the PC is restarted, after running the tools, download and install the AVG Antivirus free from the link: http://support.avg.com/SupportArticleView?urlname=Download-and-install-AVG-AntiVirus-Free
Please follow the instructions and contact us for further help.
Hello Duc,
There are three problems. One, no internet connection. Two, no connection to my ipad (I'm using it now to type), and three, already run the AVG Clear tool several times. Did not work. Always stop at that point. And the AVG Remover now just say "There are no AVG products left" - and I have run it several times as well.
