Dialog box pops up stating Network connection has changed to
Hello Andy,
This message will be appearing when you try to connect with different internet network.
Did you try connecting to a different network other than the one that you were using previously?
Do you have any option on the dialog box as allow or continue?
I use a lap top.  Mostly at home.  I don't have other networks that I automatically hook to.
There are no options.
1st box says the network is changing to
next box says the network has been changed to my network name.
Thiese boxes appear about every 10 minutes or less
I have the setting set to notify me every time the network changes
There are no options or interactive dialogue.
Running AVG Internet Security.  Several time an hour a dialog box pops up stating Network connection changed to.  Followed immediately by Network connection changed to my network name.  Should this be happening or have I been hacked?
Is there a solution to this issue as I am getting the same message every 2-3 minutes ever since I went from a wired to wireless internet connection and frankly it's annoying the crap out of me. The new network is on the list of known wi-fi networks so why is it constantly identifying and changing it to the same network over and over?
Could you please click on the "SETTINGS" and let us know what options you get?
Hello Andy,
We appreciate your efforts. We have sent you an email instruction to get connected with our technical support team. Please follow those instructions to get in touch with them and you should be able to resolve your issue. Thank you.
Hello Andy,
Thank you for the screenshot. It seems that the network connection in your computer is being changed between two networks, We suggest you to click on "Change Sharing Settings: and select one network you would like to  get connected to.
Hello Andy,
