Downloading products purchased
Hello, Roger.
I will help you with the installation of AVG Secure VPN and Password Protection. Install Secure VPN by following these steps:
>Double-click the AVG icon on your desktop to open AVG management console (formerly known as AVG Zen).
>Click the Secure VPN tile to install the program.
>Click Try it free to start 30-day trial. If you already bought a subscription for AVG Secure VPN and you are logged to your AVG MyAccount in AVG management console, your license is detected at this point.
>Click Yes to confirm installation. Restart your PC, if asked.
>Click the OFF slider so that it changes to ON. Secure VPN drivers are installed.
I have recently purchased AVG Secure VPN and AVG Password Protection as well as AVG Ultimate. The Ultimate down loaded and installed successfully but I can't find out how to down load the two others. I also wanted to down load AVG TuneUp but got the message it can't down load because I have AVG Ultimate.
To install AVG Password Protection, open AVG management console and >click the Password Protection tile to enable it. Once enabled, click the Password Protection tile in the AVG management console or click the Password Protection icon on your desktop.
>Click Scan for weaknesses to check your passwords for security and privacy issues.
Note: Password Protection protects and scans the browser that was detected as the default browser on your PC (if it was supported), but you can change it.
>If any issue is detected, click Change password next to the issue description to open your browser and follow the on-screen instructions.
If you face any difficulties, please contact us to assist further.
