ERR_CONNECTION RESET caused by enabling 'Scan encrypted (TLS and SSL) network traffic
I know the workaround fix, but my question is why do i have to disable the ssl network traffic
and why it blocks all other connecions and i get no response from the page
I don't understand the question, sounds like you already know what happened and found a solution.
Hello Yaniv. Sorry to hear about the inconvenience caused. Please follow these steps to send us diagnostic information from your computer. This information will allow us to analyze the situation and provide you with solution:
Click this link http://www.avg.com/filedir/util/AVG_SysInfo.exe to download the AVG SysInfo tool.
Run the downloaded tool.
Click Accept to confirm the license agreement, and then click Continue.
Once the screen Output created is shown, fill in any additional details, or click Attach if you want to attach any additional files, such as screenshots.
Click Send, fill in your email address, and then click Send again.
We will analyze the received files and provide you with further information.
Recently i installed avg protection since then every time i connect to my development
environment to https://xxx urls first i works fine but after few minutes i can't refresh the page and everything is stack and all connection blocks till i restart the system
If i disable 'Scan encrypted (TLS and SSL) network traffic' everything works fine
Can you please tell me what happened  ??
Hello Vladimir. Please follow these instructions to add an URL to AVG's exception list http://bit.ly/18WB2dg .
Hello Vladimir
Yes it works when i create an exception fro this url , but my question is why it blocks all other connection for diffrent sources ???
that's the real bug
