ERR_CONNECTION_RESET issue
After a recent udate, i keep getting the following issue on pretty much all websites: ERR_CONNECTION_RESET
When i disable AVG, the issue goes away and brower works fine (chrome, firefox)
Any help would be great, Thanks!
Hello Thomas,
Thank you for taking out your most valuable time to sharing the required information and we appreciate your efforts.
In this regard, we would suggest you to repair AVG Internet Security and check with the issue.
To repair the AVG Internet Security app, just follow these steps:
Click on Windows+ R and Search for appwiz.cpl
Locate AVG Internet Security and click on it
Click on Change
When the AVG Setup wizard appears, click on the Repair option
Restart your device - don’t miss this step!
If you still need any assistance, please let us know and we will assist you.
Looking forward for your response.
Hello Thomas,
I see that after a recent update you are getting website error connection reset message on all websites.
I really understand how inconvenience this might be for you.
I’m going to try my best to help make things better for you.
Could you please confirm on which device you are getting this issue? Is it on your mobile or computer/laptop?
Please provide us the operating system version of your device.
Could you please let me know if you disabled any particular function of AVG and checked or you disabled all the features and checked?
If possible, could you change the type of connection and try to connect again — 4G/3G to Wi-Fi or vice versa. Also restart your device and check again.
It may also help us to diagnose the issue you are experiencing if you can attach a screenshot of the problem. If you are not sure how to make a screenshot on your device, please find instructions for a variety of devices here: | AVG (https://support.avg.com/SupportArticleView?l=en&urlName=avg-create-screenshot&q=screenshot)
Awaiting for your response.
Hello Thomas,
Click on Change
Hello Thomas,
