Error code oxcoo70643 how to fix it
Carlos,
We understand that you are facing issues with installing AVG program. We apologize, do not worry, we will do our best to resolve the issue.
Is there any other Antivirus program like McAfee or AVG Antivirus program installed on your system? If so, please uninstall it and then we would request you to run the AVG remover tool to remove all the remnants of the failed installation.
Please reboot your device http://avgclick.me/rebootintosafemode in safe mode and refer this article to uninstall http://avgclick.me/UninstallAVGAV your AVG program.
error code ox coo70643 how to fix it
Then kindly remove the AVG folders manually as suggested below. Go to Run window (press windows key and R key simultaneously) and type the following comments to delete the folders.
1. Type  “Temp” and press enter, remove all the files.
2.  “%temp%” and remove all the files.
3.  %appdata% - Remove all the AVG folders.
4.  %programdata% - Open the AVG folder and remove the old files. Please go to c: drive-> program files and delete the AVG files.
Reboot your device in normal mode and proceed with the installation using this link: http://www.avg.com/us-en/download.
Let us know if you face any difficulties, thank you!
Carlos,
