Hello Ting,
You've reached the AVG community support forum.
We regret the inconvenience this has caused you. We'll certainly look into this and help you. We kindly request further information on the softwares that are not functioning properly following the installation of AVG Internet Security. Moreover, could you please clarify how you came to the conclusion that AVG is responsible for the issue.
In order to confirm whether AVG Internet Security is the cause of the Issue, kindly disable it and verify if the issue persists. To proceed, please click on the provided link. : | AVG (https://support.avg.com/SupportArticleView?l=en&urlName=disable-avg-antivirus&q=disable&supportType=home)
Looking forward to hearing from you.
After installing the AVG caused 2 of my existing software can't work.
What is the problems
Hello Ting,
