Fine Wood Working DVD problem
Hello Gerry,
We regret for the inconvenience caused. Please check whether you could find the files of the Fine Wood software on the virus vault of the AVG program. If so please try to restore the files from the virus vault and add the files to the exception list and check whether you could access the program. Please follow the instructions on the article http://support.avg.com/SupportArticleView?urlname=What-should-I-do-with-files-in-Virus-Vault to restore files from virus vault and have a look at this article http://avgclick.me/AddException to add the program to exception list.
Installed the Fine Wood Working digital archive DVD published by the Taunton Press.  Started it running.  Selected the search option to find references in the 40 year archive.  AVG blocked / deleted various processes & directories.  Tech support at the Fine Wood Working site said this has never been reported as a problem.  Is there a problem, and what should I do.
Hello Gerry,
That worked.  Thank you for the quick response.
You are welcome, Gerry. We appreciate your valuable effort in fixing it. Your patience is much appreciated. Feel free to contact us for any further assistance. Thank you.
