Hello Alan,
We will work together to fix this issue. Have you checked the firewall Network profile whether it is still in private mode? Also, check the System rules if all the configurations has been allowed.
When first trying to connect my LG TV to my laptop I had connection problems that were solved by following these instructions:
Change AVG Firewall network profile to private (open AVG Internet Security > menu > settings > components > firewall > customize > network profile > change all the networks from public to private) then go to Firewall customize settings again > scroll down > click on system rules > enable all the system rules if they're not configured then click OK.
After a Windows 10 update today, this is no longer working. However, I updated my AVG software a few days ago so the problem is quite likely related to the updated AVG.
Switching the firewall off allows the connection between the TV and laptop so the issue is related to the firewall.
Any suggestions on how to fix this?
Hi Rafał,
We appreciate your efforts in working towards fixing the issue.
Upon checking the conversation, we see that the Internet connection sharing mode wasn't mentioned earlier.
Would you be so kind to try enabling it to check if it helps?
To do so : Open AVG Internet Security - Menu - Settings - Full protection - Enhanced firewall - Enable 'Internet connection sharing mode' by checking it.
If issue persists, we request you to write back in your own/individual post to keep the conversation simple.
That worked - thank you very much!
You are most welcome.
Glad to know that your issue has been resolved.
Feel free to contact us if you need assistance with AVG.
Yes, I have done both of those. Still not working
Hi Rafał,
Please repair avgclick.me/RepairAVG AVG Internet Security and check if that fix the issue.
