Firewall problem
Warren, Registered email address… It's the email address that you use to log onto the Community. If you didn't receive the instructions email check your email spam/junk folder.
Hello Warren,
I apologize for the inconvenience caused. I kindly request you to follow the instructions in the email which I have just sent to your registered email address .Kindly follow the instructions in the email to get connected with AVG Technical Support team for getting assistance in resolving the issue.
AVG firewall is blocking all access to the internet.  I have checked the trusted sites and they are still all there.  This problem started this morning.  To use the internet I have to completely turn off the firewall.  Any suggestions.  I feel vulnerable.  Thanks
Hello Warren,
