Firewall problem?
Hello Trevor,
We will check and help you to resolve it. You need to set application rules and network rules in AVG Internet Security in order to firewall allow application. Refer the below article to know how to configure firewall :
Setting up Enhanced Firewall Basic rules in AVG AntiVirus
Setting up Enhanced Firewall Application rules in AVG AntiVirus
Please try the above steps and let us know if its help you. Thank you.
Hello Trevor,
Hello Veeramani,
Apoligies for taking so long to repy to your suggestions, which I thank you for. The steps didn't help, but it turned out that my network had somehow become untrusted. Once I reset it to trusted my problem was solved.
Thanks, Trevor
In the past few days I've been unable to connect to my Synology NAS unless I temporarily disable my AVG firewall. Prior to that I had no problems. Any ideas please as to why this problem has suddenly appeared?
Hello Veeramani,
Thanks, Trevor
Appreciate your efforts, Trevor. We're glad to know that you've managed to fix the issue. Thank you for updating the status. Have a great day. Stay safe!
