Fix 2015 freezing and slowing PC with more than minimum system requirements
Hello Norman, sorry to know this. Have you tried uninstall AVG using AVG remover tool? Please try uninstall AVG using AVG remover tool.Please run AVG remover tool based on your OS (32-bit or 64-bit) to completely remove AVG and then re install. To determine whether your OS is a 32-bit or 64-bit, please click on this link. http://support.microsoft.com/en-us/kb/827218
Please install the latest version of AVG again through the below link.
http://support.avg.com/SupportArticleView?urlname=How-to-download-and-install-AVG
Updated to 2015 version  yesterday (I was running avg_free_x64_all_2014_4744a7830). The 2015 version actually slowed down my PC and made it freeze, forcing me to cold reboot.
I ended up un-installing the 2015 version, and now the PC runs fine.
Now I can't reinstall the 2014 version because of stupid forced "the version you are installing is outdated, downloading newer version". I can't find the "check version=0" command for command-line install.
I also saw the notice here on AVG.COM stating we will be forced to update to 2015 soon. If 2015 is not fixed I will switch to Zone Alarm or something else, I am tired of being forced to install AVG every year and have my pc slow down more and more each year!
FIX AVG Antivirus 2015 NOW!
My system:
ASUS Motherboard Model M2N32-SLI DELUXE (I built the system NEW years ago)
  Total amount of system memory 4.00 GB RAM
  System type 64-bit operating system
  Number of processor cores 2
CPU: AMD Athlon ™ 64 X2 Dual Core Processor 3800+ 2.01GHz
OS: Windows 7 Ultimate Edition 64-bit
Storage
  Total size of hard disk(s) 2012 GB
  Disk partition (C:) 111 GB Free (149 GB Total)
  Media drive (D:) CD/DVD
  Disk partition (E:) 25 GB Free (932 GB Total)
  Disk partition (F:) 39 GB Free (932 GB Total) (Pagefile.sys is on this drive, 4,194,304kbsize [I edit HD video and audio on this PC])
Graphics
  Display adapter type NVIDIA GeForce 8400 GS (Microsoft Corporation - WDDM v1.1)
  Total available graphics memory 2047 MB
        Dedicated graphics memory 256 MB
        Dedicated system memory 0 MB
        Shared system memory 1791 MB
  Display adapter driver version 8.15.11.8593
  Primary monitor resolution 1280x1024
  DirectX version DirectX 10
Network
  Network Adapter NVIDIA nForce Networking Controller
POWER SUPPLY: 800 WATTS PEAK POWER capability.
