Hello Robert,
I will certainly check this for you.
Please share the screenshot http://avgclick.me/getscreenshot of the error message to assist further.
I down loaded avg and it says I am not protected. I click fix now and it does not work. what can I do to fix the fix now ?
Robert, For your info, just in case that you are unaware, you can post the screenshot here in your topic. Click on 'Answer' & then click on the 'Image' [mountain symbol] & follow the instructions.
Hello Robert,
