Fix Problem process in AVG PC Tuneup goes on forever. Total score on the main tune up page shows 75% due to that and never reaches 100%. I have purchased AVG Ultimate in the last month and facing these issues. Please let me know how to resolve this issue.
Hello Mandar,
Please be informed that if your AVG PC TuneUp percentage is more then 60% then your computer performance is good. If you will try to have 100% then it will might ask you to delete some Windows files which will be harmful for your computer. However, please share a screenshot of the AVG PC TuneUp to assist you further. You can post the screenshot here on your topic. Click on 'Answer' & then click on the 'Image' [mountain symbol] & follow the instructions.
Best regards,
Mandar,
Thank you for sharing the screenshots. I request you to repair your AVG PC Tuneup as suggested here: http://support.avg.com/SupportArticleView?urlname=How-to-repair-AVG and check if it helps. We are here if you need any help.
Mandar,
Hello Mandar,
I'm really sorry to hear that you're still experiencing issues with AVG PC TuneUP "Fix problem" component. I have sent you an email, please follow the email instruction to connect with us remotely. We will check with your installed AVG program and we will help you to fix the issue as quickly and effectively possible.
Best regards,
Hello Mandar,
Best regards,
Did as you suggested. Still the same.
Nothing new after doing all the steps. Same as before. shows 1 problem on main screen and after clicking it scan just goes on and on forever. Started to feel a bit fed up now.
