Flash Player Exploit Issues
Hi Colin. generally AVG detects threats before it can do any harm to your PC. As you say that AVG detected and removed the exploits then it means that you are safe and no further action is necessary. If you wish you can just run a full scan of your PC in order to double check.
You can learn more about Flash Player Exploits at the following links:
http://bit.ly/1G2xfE9.
http://bit.ly/1HGMslA.
Recently AVG detected and removed 2 Flash Player exploits, but the affected code, (if affected) does it remain as the modified or does AVG detect and remove it before it can change it? Also, what can be accomplished via a Flash Player exploit by the hacker/program? Can I be locked out of my computer, etc? Just curious & worried as it's the first time I've had an exploit but since its a Flash Player one I'm not too sure what can happen even though I did a bit of research. Thanks!
