Full scan for iMAC does not complete beyond 98%
ok got it done a different way.In the BOOTCAMP partition(Win10) I:
1)updated WIN10
2)uninstalled AVG Tune Up
3) repaired AVG security(FREE edition)
 MacScanner ran to the 100% and this result 9 threats
User-added image
Hi Lex,
I'm sorry to hear that the scan is unable to complete. Please try to repair the AVG Internet Security and check once.
To repair your AVG please follow these instructions:
1. Go to Start -> Control Panel.
2. Open (Programs) -> Programs and Features, or Add or Remove Programs.
3. Select AVG in the list of programs.
4. Click the Change or Change/Remove button.
5. Select Repair.
6. Follow the instructions on your screen to complete the installation.
7. Restart your computer.
In case the issue persists, please provide me a screenshot of the error. Here is a link with the steps to create a screenshot: http://avgclick.me/getscreenshot . You can post the screenshot here in your topic. Click on 'Answer' & then click on the 'Image' [mountain symbol] & follow the instructions.
Hi, I have the same problem  as mentioned earlier.Have Siera 10.12.6 and BOOTCAMP Win10 on board. For three days I let the scan run for 9 hours and then it gets stuck at 98% (has detected 7 threats!) but blocks my system and I have to pull the plug.I am on a 30 day FREE trial for the PRO version after I have always run the free version.
Last message at 98% was   /volumes/BOOTCAMP/Program Files (x 86)/AVG/Setup/license_us.html
I am working in Belgium Thx
Thx but I will leave all 9 threats in quarantine. I know too little what each of the threats represent.  safety first is my motto.
Thank you for the update.
I appreciate your efforts in trying the workaround.
Please go ahead in resolving the threat detection and keep us informed about the status.
Akash, I was running the Mac Scanner  on my MAC HD and what you describe as a possible solution is a windows programme. Do you want me to leave the MAC HD and open the Win10 section to perform your recommended repair???
You are most welcome.
Thank you for understanding.
If they are trusted files then you can ignore and if you would like to submit those files for analysis you can use this link: http://www.avg.com/submit-sample .
