Gear Icon and auto shut down
Hello Cindy,
I understand the inconvenience. It would be helpful if you could provide the screenshot http://support.avg.com/SupportArticleView?urlname=How-to-create-a-screenshot of AVG Interface to check and assist further.
I purchased AVG Internet Security in May of 2017 (1 year license).  There is no longer a gear icon next to scan.  I want to change my automatic scheduled scan.  Also, computer is no longer shutting down after auto scan.
I have not received a requirements e-mail.
@ Simon Shearer
Simon, Have you received the requirements email from Bhuvaneswari Vairavan (AVG Technologies)?
My AVG has stopped shutting down after the scan completes. It first did this about 2 weeks ago just after the update to Version 17.9.3040 on 21/12/17
Cindy, For your info, just in case that you are unaware, you can post the screenshot here in your topic. Click on 'Answer' & then click on the 'Image' [mountain symbol] & follow the instructions.
Simon, this is the known issue. To analyze the issue further with the scan settings, we need to submit your concern to the senior technicians with the diagnostic files. Please follow the email steps and provide the necessary details to assist further.
Hello Cindy,
Sorry for the trouble, Simon.
Could you recheck your email? We have resent that email to collect log files required for escalation.You can share the screenshot via email with scan settings interface where you have checked the auto shut down option.
Simon,
I appreciate your efforts and patience so far. To analyze the issue further, I need to submit your concern to our senior technicians along with other diagnostic logs. I have sent you an email with steps on how to collect and upload the data required for analyzing your issue. Please check your inbox and spam/junk folder as well.
Thanks for this, but what data do you want? The scan is set to shut down on completion, by ticking the box on the 'Scheduling' Screen, just as it always has been, but now it doesn't shut down like it always did before.
