Sinds kort GEEN TOEGANG op verschillende websites meer op mn PC…HOE KAN IK DAT VERANDEREN…??? Jo
Glad to know that, Jo. Appreciate your technical knowledge.
Thank you for updating the status. Have a great day. Stay safe!
Thank you for writing back to us, Jo.
In this case, we'd request you to temporarily disable the individual shields/components of your AVG Internet Security & check which shield is causing this issue.
Refer to this article to temporarily disable the individual shields/components of your AVG Internet Security.
Keep us updated.
Hello Jo,
AVG support through the Community channel is available only in English.
You can make use of Google Translator ( https://translate.google.com /) to translate the below message.
This isn't the usual behavior of AVG program. We'll be happy to look into this immediately.
Could you please let us know whether you get any specific error while trying to access those websites?
Keep us posted to resolve this.
Hallo,
Na veel uitproberen op de PC EINDELIJK oplossing gevonden. HET SYSTEEM TERUG ZETTEN naar VORIGE BACKUP. Na een automatische update van Windows7 begon mijn PC bovenstaande problemen te vertonen. NU GELUKKIG ALLE WEBSITES WEER BENADERBAAR…!!
VEEL DANK VOOR JULLIE HULP EN SUPPORT…MET DANKBARE EN VRIENDELIJKE GROET, Jo
