General and Disk Write Error
i had the same problem, i tried removing the AVG and reloading it, it worked, thanks
io games
Hi Brian,
I will help you with the issue
You can solve this issue by Uninstalling AVG program from control panel
And then running AVG remover tool. After that you can reinstall AVG program.
Follow the below links to know how to do it.
Uninstall AVG http://avgread.me/1IVT2Um
Download and run the AVG remover tool using the link below
http://www.avg.com/tools#tba2
Download the your AVG Program  from www.AVG.com/downlaod and reinstall it.
please let us know if you face any issue
 Thank you
When trying to an update to AVG for what it says is in the computer category, it comes back with a general error. When I try to use the installation it comes back with a disk write error. The code is 0xE001C00D
I am using Windows 10.
Thank you for sharing the feedback, Mira.
We appreciate your efforts in resolving this issue.
Hi Brian,
 Thank you
io games
