Hi Cichy,
We'll work together to get this sorted out. When you ran a scan with AVG did you get any error message? If so please share us the screenshot of the error message to check and assist you further. Please refer to this article ( http://support.avg.com/SupportArticleView?urlname=How-to-create-a-screenshot) to know how to take a screenshot.
Thanks,
Vishnu Vardan
hi.
Yesterday I'm installing viruses. Immediately I unpluged internet cable and I using AVG scanned. A few files stayed in program data, windows and files in local\Temp My attention has been returned by two process: Gjagent and Noise Italian Juest to which the location is not available. I have turned off these processes and are now writing to you for help.
Hi Cichy,
Thanks,
Vishnu Vardan
Cichy, For your info, just in case that you are unaware, you can post the screenshot here in your topic. Click on 'Answer' & then click on the 'Image' [mountain symbol] & follow the instructions.
