Hacker shield still not up and running
Charlene,
Unfortunately, we do not have time frame for this update. We expect this might be fixed soon, however you can reinstall it and check if it helps.
Go to Control Panel -> Programs and features -> Uninstall -> uninstall AVG Internet Security and reinstall it as suggested here: http://support.avg.com/SupportArticleView?urlname=Download-and-install-AVG-Protection . Activate the product using your email address and  password.
timeframe please when this will be fixed and are you going to send an update to click on to get this updated and running properly. thanks.
Charlene,
