Hard Drive Replacement
HI
I am about to replace the hard drive on my Win 10 laptop.
I have current licences/subscriptions to both AVG Ultimate and AVG Secure VPN, how do I remove the licence from the current HD and swap to the new HD as I will be starting with a new win 10 install.
Regards
Keith
Hi Keith,
The number of devices will be recognized only if the code is active on any of the devices.
If you aren't using old hard drive, then it means that AVG is not active on it.
You need not remove it from old hard drive as you have subscribed for AVG Multi-Device products.
If you need instruction on how to install and activate it on new hard drive, do let us know.
Hi Keith,
