Having problems with a particular program AVS audio editor
Hi Stephen,
Is there any error message displayed? If yes, could you please send me screenshot http://avgclick.me/createascreenshot of it? What is the status if you temporarily disable AVG http://avgclick.me/TempDisableAVG?
It seems to load all the way but it will not allow me to use the program I am not sure what the deal is it worked fine before. It stops working for me. It is the avs audio editor.
Hi Stephen,
