Help avg unable to start
Hello Adel,
We regret for the inconvenience caused. We suggest you to repair the AVG Internet Security Unlimited once using the link: http://avgread.me/1BVxDSY and then check whether you are getting the error code. If you still get any error message, please click on the following link http://support.avg.com/SupportArticleView?urlname=How-to-create-a-screenshot  to send the screen shot. Please feel free to get back to us and we will be happy to help you.
the application was unable to start correctly(0xc0000142) click ok to close the application
Adel / Dolores, For your info, just in case that you are unaware, you can post the screenshot here in your topic. Click on 'Answer' & then click on the 'Image' [mountain symbol] & follow the instructions.
Hello Dolores,
We are sorry to hear that AVG installed is not working in one of your computer. Could you please let us know whether you are able to open the AVG Program or getting any error message when you try to open AVG? Please do send us the screen of the issue you are facing with using the link http://support.avg.com/SupportArticleView?urlname=How-to-create-a-screenshot  to send the screen shot.
Thank you for understanding.
I paid for 2 subcrritions for AVG. One for each of my computers.  It works on only one but foes work. help
