We're sorry for the inconvenience caused. Please share us the screenshot of the error message you're referring to, so that we can check & assist you further. You can post the screenshot here in your topic. Click on Answer & then click on the Image [mountain symbol] & follow the instructions. Thanks in advance!
Hello! Please help! After I upgraded to a paid version and did some recommended cleaning (decluttering) of my PC i have an error every time i try to upload a file - both in Edge and Chrome browsers! Maybe some important file was deleted but i dont know which((( The error is like when the uploading window is opening then i can't press anything there and immediately it gets "frozen" and then i have to force close it… Restart of PC doesnt help… I would appreciate any help, thank you.
Hello Kat. Thank you for returning and updating the status. We are glad to hear that the issue has been resolved. If you need any further help, do not hesitate to let us know.
