On 3/10/16, I was infected with a virus and Trojans cloud surfing sites .ru about 647 attacks. AVG was completely overwhelmed and I had to cut my internet connection not recover more. After 1 day of work, I managed to fix almost anything with antivirus and anti malware other than AGV which are available on the web (coolman etc … There I only 4 parasites lines that I can not to delete - can you do something for me I am a customer at home for at least 5 years Thanks for your help…
[-] Clé: HKU.DEFAULT\Software\bnl{y<br> [#] Clé : HKU\S-1-5-18\Software\bnl{y
[-] Clé : HKLM\SOFTWARE\bnl{y<br> [-] Clé [x64] HKLM\SOFTWARE\bnl{y
Hello Pierre,
We are sorry to know that you are unable to remove some of the unwanted files from your computer. Please do not worry, in this case, we will email you a link to get connected to the advanced support, you can follow the same and the remote technicians will resolve the issue for you.
Hello Pierre,
